arkrzrbacks
Did a 2,9,hold reset and now just flashes startup screen (Bearcat BCD996P2 screen),does not go any further. How do I fix?
Your Reset cleared all programming from the scanner.Did a 2,9,hold reset and now just flashes startup screen (Bearcat BCD996P2 screen),does not go any further. How do I fix?
OK, since this would not be a warranty issue, I'd still try to reset again, just in case the first time went astray. I'd also pop the case & check for any loose cables and/or components on the boards.No have had it several years, was working fine until reset.
Did you ever try doing a software update which was on or about the end of March 2018? The latest version(1.08.01) We both have the same BCD-996P2. They are highly reliable base/mobile scanners.No have had it several years, was working fine until reset.
