BCD996P2 takes forever to program
RRR
OFFLINE
USA
Is there any way to speed up the programming time between my computer, and my BCD996P2's? I use a standard USB adapter from my computer, to the front port of the scanner to program it. I have about 160 "systems" (several with only one channel) and it takes around 45 mins. to download the entire thing to the scanners. Consistent with all of my BCD996P2's.
Is there a faster way to program these? (Rear serial? Faster cable?)
GTR8000
NY/NJ Database Guy
BEE00
Not enough details to properly diagnose.
  • What software? ProScan? FreeScan? Butel?
  • What is the size of the database file?
  • What OS? Windows 10? 7?
  • Is the USB cable plugged directly into a USB port on the computer, or going through a hub?
RRR
OFFLINE
USA
Butel, not sure of the file, nothing huge, Win 7, USB directly connected to laptop
GTR8000
NY/NJ Database Guy
BEE00
If you haven't already installed ProScan on that laptop, I would install it (30 day fully functional trial) and see how long it takes to download the scanner's programming.
iMONITOR
Silent Key
S.E. Michigan
Are you just programming a few changes or the entire program each time? Are you also deleting everything before uploading the programming? All those steps take more time, often needlessly.
tvengr
Well Known Member
Baltimore County, MD
Sounds like you are using ARC-XT or ARC-XT Pro. Use the USB port on the front of the scanner. Go to the Scanner tab and Communications Setup. Click on AutoDetect Scanner and OK. Then try again. You are correct that it takes a lot of time to upload large files. I don't believe that there is a faster method than above.
  • Like
Reactions: RRR
RRR
OFFLINE
USA
That's what I've been doing. Had it for years, always been slow. Didn't know if there was a faster way.
Thanks all.
Wilmington DE
I program my BCD996P2 using freescan, running on a virtual windows machine on my iMac thru the rear serial port using a usb to DB9 serial cable at top speed. Even erasing everything and reprogramming everything takes maybe 1-2 minutes total time. Sounds to me like either your software has an issue or your usb connection has an issue.
RRR
OFFLINE
USA
ARC-XT Pro, even with different computers, different cables, it is still the same.
Would it help if I do a "Factory / master reset" of the scanner first? I usually change a lot of things whenever I refresh a codeplug.
(If so, what is the process of doing a master reset of the 996P2?)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
When's the last time you did a full virus / malware scan? Viruses or similar can be lurking in the background and hogging your CPU. Check your task manager and see what is running. It's evident that something is hogging either the USB port or the CPU...Mike
AKJohnny
Scanner Addict
Kendall County, IL
Have you tried different usb cables? I’ve had slow communications with cheap cables before. 45 minutes is way too slow, there is a problem somewhere.
  • Like
Reactions: RRR
RRR
OFFLINE
USA
I'll check it when I get back to it (The one with the largest file) and report back. Much appreciated
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Before you do a hard reset, dump the contents of your scanner so you can restore it later....Mike
  • Like
Reactions: RRR
RRR
OFFLINE
USA
Ok, the only Baudrate I can find is the "GPS Baudrate" and it is a whopping 4800. (Anything higher, and my Uniden GPS puck won't work)
Here is the rundown;
- Memory= 19%
- System (168) = 33%
- Site (180) = 18%
- Chan (5687) = 22%
Firmware is 1.08.1
And I have the codeplug saved, always do!
KevinC
Other
Super Moderator
Home
- Memory= 19%
- Site (180) = 18%
- Chan (5687) = 22%
Firmware is 1.08.1
I believe you should have the option for setting the front and rear ports separately.
