- Joined
- Jan 1, 2009
- Messages
- 10
I have my scanner programmed to listen to a Motorola Type II SmartZone system in my county. I have it set up to use a site that is 2 miles away from my house. I have an antenna on my roof.
The problem i am getting is that the audio gets bad at some points. Sometimes it turns to static and sometimes it cuts out. It also sometimes makes a noise that an analog scanner makes if you try to tune it to a digital channel. Are there any settings i need to adjust to make it work correctly? I have tried bringing a portable radio home from my fire department and I had no issues receiving audio.
Any help is greatly appreciated
