I wish there were some type of option to only have the alert sound once per progammed freq/TG until after the scanner resumes scanning. I don't use the alert per freq/TG because it sounds each time the freq/TG breaks squelch. This can become a real nuisance. I know that the arguement would be under the current configuration, you will still be alerted if you are away from the scanner and miss the first alert, but I do a lot of unattended recording, and having the alert sound each time the scanner breaks squelch on say a mutual aid channel that has become constantly active because of a large scale event can drive you batty and make you want to throw the recording away. Just my .02 on the alert. Come on, a programmable alert that can be set to squelch break OR deactivated until the scanner leaves the freq/TG... like the logging feature on bcTool and some of the other software.
Dewey
