BCD996T Headphone Jack Problem
rgchristy
Delco, PA
Hi,
When I plug in a set of headphones (stereo or mono), the bottom speaker does not mute. The headphones work fine. It always worked until I decided to try and listen to 2 scanners at once (BCD996T and PSR-600) through 1 set of headphones (Which I know now was a dumb idea without using a mixer and/or combiner circuit). I used a stereo "T" (2 male to 1 female).
So here's my questions:
1. Has anyone run across this before? (I did a search with negative results)
2. How screwed am I?
3a. Can I repair this myself (resistor replacement, etc.) or is this a blown circuit?
3b. Does it need to go back to Uniden for repair?
Thanks in advance.
Happy Thanksgiving,
Rich
Brillian
Central Pennsylvania
Hi,
Thanks in advance.
Happy Thanksgiving,
Rich
The only thing I can think of is reboot your scanner to factory defaults, and hope for the best. If it's under warranty, send it in for repair.
