bcd996t programming question?
kc9neq
Illinois
i just received a new bcd99tt scanner. i tried to program the unit with arc996-pro software but when i press the scan button it scans all of the preprogrammed frequencies in the unit.
how to i turn these off or delete them from the unit. i will never use all of the preprogrammed frequencies.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I clicked on BCD996T up at the top, selected READ DATA - then when it read in the list of all of the ones programmed in the scanner I selected DELETE ALL.
Then, once they were all removed, I commenced with adding the systems I wanted.
Of course if you wanted to keep any of the systems in there that were preprogrammed, you'll have to selectively delete.
Mike
hankv
You have two choices:
1. Turn off the Quick Keys for all the Pre-Programmed Systems - Tedious!
2. SAVE the Pre-Programmed Systems to your computer (NEVER say never) and then load (while erasing scanner memory) ONLY what you want to monitor. I use Uniden's UASD (free) software, so I can't tell you how to do it with arc996. :wink:
