bcd996t
Bigpaul00
computer wont reconize the scanner, ihave windows vista which isnt on the sight at uniden........ any ideas??
garys
Eastern MA
Check your Comm Port settings, make sure the configuration on the scanner is right. If you are using a USB to Serial adapter or the Uniden USB-1 cable make sure you've installed the drivers. What software are you using?
jcecklund
Kansas City
Try this
A friend of mine had the same problem and he used or forced the program to use com port 9
I now works perfectly.
It shares is wireless card and does not interfere.
Hope this helps.
