hello
I wanted your advice on this thing:
I have a bcd996xt and on the motherboard I picked out point "DISC" for the signal discriminator output, with a shielded cable by plugging it into a jack on the rear panel: central wire and ground on the chassis of the equipment.
According to you, or those who have already made ​​this change, the 10k resistor is inserted or not?
The signal is clean, but I get the impression that it is low ..
Thanks for the advice that you will give me
Greetings from Rome
Greetings from Rome
