MPSMP
Does anyone have a file program file with the sites for the metro that I could download on to My new scanner? or know were to download one at?
Please check your keyboard caps locks button, it maybe stuck on.UNBELIVEABLE, GUESS I AM LEARNING TO ASSEMBLE BETTER THESE DAYS. i GET A KICK OUT OF PUTTING FILES TOGETHER FOR CITIES AND REGIONS ALL OVER. I BUILT THE COUNTIES AROUND MINNEAPOLIS SO YOU PROBABLY HAVE MORE THAN YOU NEED. YOU COULD ASSIGN THINGS DIFFERENT TO QUICK KEYS WITH FREESCAN I'M SURE BETTER THAN WHAT I DID. I FIGURED YOU WANTED LAW ENFORCEMENT STUFF BUT I ADDED FIRE ALSO. HERE IN MISSOURI, IF THERE IS A BAD ACCIDENT, MANY TIMES YOU HEAR THE CALL TO SEND FIRE TRUCKS OR THE AMBULANCE BEFORE YOU HEAR THAT POLICE HAVE BEEN DISPATCHED. ALSO MANY OF THE LAW ENFORECENT AGENCIES HAVE GONE TO MORE "PRIVATE" FORMS OF COMMINICATION BUT THE FIRE IS STILL PRETTY OPEN YOUI CAN LOOK AT THE FILE IN FREESCAN AND LOOK TO HOW YOU CAN CREATE FILES ON YOUR OWN. IN THE 396XT, THE ENTIRE US ALL STATES HIGHWAY PATROL TRUNKING SYSTEMS ARE IN THE RADIO. SINCE YOU HAVE A FILE THAT WORKS, DO A RESET OF YOUR RADIO, 2, 9, HOLD, AND HIT THE POWER BUTTON. THE RADIO SESETS AND THEN THE RADIO IS LOADED WITH THE US FILE. THEN SAVE THIS TO A FREESCAN FILE AND YOU CAN SEE HOW UNIDEN CREATED THE FILES. WHEN YOU ARE FINISHED, RELOAD YOUR FILE FOR MINNEAPOLIS.
I have found there are many reasons why others *choose* to use uppercase type. It could be as simple as having one's arm in a sling to being near-blind and elderly...Please check your keyboard caps locks button, it maybe stuck on.
My local newspaper editor has much the same "temp" issue (he is a "leftie", so he needs to learn the "right" way to do things!). So rather than get excited, I thought, maybe there is a legitimate reason for all CAPS.Sorry about the type, I've had a stroke and my right side is hamped. My right arm has become a flyswatter.
