hello
I have just the bcd996xt and I'm trying to use it but I can not quite do that with dsd +
I connect the stereo cable from the PC microphone output to the receiver via the REC does not come through and taken out Speacker very strong signal that generates errors in dsd + by adjusting the levels in the radio and the controls on the PC.
Is there a way to pick up the signal from the discriminator?
With other receivers changed the tap and everything is ok with dongle RTL and SDR signal clear and clean ...
I hope I was clear in explaining the problem.
Thank you for your attention.
Greetings from Rome
Greetings from Rome
