BCD996XT Radio IDs
ofd8001
Louisville, KY
If you are talking about the unique Radio ID number programmed for each radio on a P25 System, yes.
In the Settings Menu, the Disp. Unit ID has to be On.
What I did was create a separate group in my programming software called "Unit IDs". In the Talkgroup column, I entered the six digit number with an "i" in front of the number. (The 96XT series requires the "i" in front of the number). In the Alpha Tag column, I entered a description of what that number was.
For Example (with Unit 8001's mobile radio having an ID number of 180010):
Talkgroup Alpha Tag
i180010 8001 Mobile
(Couldn't figure out how to tab this to align the columns)
W8RMH
Feed Provider Since 2012
This will work on Motorola Type II analog trunk systems too. Note: The scanner will stop on all transmissions from those radios, regardless of talk group, including private calls and phone patches.
So Far Away....
Ok,heres one Ive been pondering for a bit...
How dose the 996XT/396XT show Patches,vs ICalls,vs RadioIDs?
Systems Ive been monitoring in a couple different states will show up in either a
4 or 5 digit format..
example...UID: i12345 or UID: i1234...
My GREs will indicate a patch vs a normal RID...But the Unidens only show the i12345
how to tell,or is there a setting to tweak for the readout..
