I am using Windows 10 on my HP
The front port on my 996xt does not work anymore so I'm using the rear port with a USB Serial Cable
When I open the Butel software program and click on scanner, then Communication Setup, then it chooses the correct port but the lowest the software will take me is to 9600 Baud Rate. The back port requires 4800 ... unless I turn everything on in a certain sequence ... but it has stopped working or I'm not doing it right)
There is probably a lot more you need to know ...
I'm not sure if it's the scanner, HP, software .... but I'm open to suggestions.
