Nothing yet!![]()
Sorry, were you asking me ?
No simulcast in my neck of the woods so I can't comment.
The problem DDan is having is probably a Q's that Uniden should be able to address. ?
Nothing yet!![]()
This doesn't sound like an issue a firmware update could fix either.
BTW, I have no problem with my HP-1s - you could buy one of those. So quit complaining - just sell your scanner and buy a different one.
Shell
Wouldn't it be nice someone from Uniden or a spoke person to give a press release or whatever about the Uniden BCD996XT 1.5 firmware or which ever firmware they do come out to fix the issues with the scanner instead of leaving us in the dark.
C'mon Shell! Selling is not an option! At least not for me.
I love my XT series scanners and would not give them up for anything!
They are by far, better scanners than the GRE line for myself anyway. I do use my XT scanners for most of our areas VHF stuff which as you know is the majority of what we have here.
The XT radios work fantastic for that. The GRE's are poor due to pager signal problems.
I also have the HP-1 and I also like it a lot. I find that it is a good receiver to just have running in the background and also recording which is a fantastic feature.
I do not, however, agree with your statement that there is nothing wrong with the XT radios. Why do all of my other radios, including Unidens very own older T model, receive the P25 simulcast systems fine while the XT's do not?
That tells me there is indeed something wrong with just the XT series in the way they attempt to tune a P25 simulcast datastream.
I don't care where I am at, when I can sit the T and XT side by side and hear the P25 signal clear as a bell on the older T model or on any digital GRE but not at all on the XT series, there is something wrong with the XT's P25 design plain and simple. I'm not sure how you can argue with what I'm seeing and stating here. I see this 100% of the time when I do a side by side test using the same antennas and other equipment.
In Unidens defense, I was monitoring some activity last evening that went from St. Louis County out to St. Charles County. Our county helicopter was sent to St. Charles county. For some reason, I put the St. Charles sherriff frequency into a digital GRE. St. Charles county sheriff is a single channel P25 signal in case you did not know that.
I left the XT Uniden on the counties channels as they were still working the call as well.
Our counties Air One came up on the single channel St. Charles county channel in P25 mode. That was cool! After a few seconds, things went all goofy and it sounded exactly like they went encrypted.
So I quickly put St. Charles counties P25 freq into the XT Uniden and it decoded the signal clear as a bell! Why this happened is beyond me as I’ve used the GRE before for this single channel out of St. Charles. Perhaps the signal was being messed with from a pager signal near me. That is very likely. That is why I generally do not use the GRE’s here for anything other than 700 MHz and higher systems as they desense or overload from the (local to me) paging signals.
IMHO, the XT series are great radios but they "can" suck at decoding P25 simulcast systems for some users. For those systems, I use a GRE or the T model Uniden as my fix.
Having multiple radios is not an option for many due to cost usually and for those users, I may agree with you that selling and replacing with something that does work may make the most sense. I personally will be taken to the grave with my radios - all of them! I find a way to make the most from each one regardless if it has a specific problem. I’ll just use it for what it does best and forget the rest. I still use old xtal scanners for our highway patrol! They are fantastic for that! Not for much longer though. I’ll find another use for them though when that time comes.
With all that said, I do wish Uniden would address this and make the manual settings from the T models available in the XT models. I can only hope but at the same time, I can live without as I have many other radios to choose from. Of course the above wish is only valid if they can do this with firmware.
edit: Shelly, I sent you a PM unrelated to this thread!
He was asking about recommendations. I gave him one.
I realize that but his question was the thread hijack and your post just continued the thread jack. Neither of them were related to the current firmware for the XT scanners which is the subject of this thread.
