A Working Digital AGC is on my wish list
I sure miss having a working AGC. The volume varies from barely audible to blast-me-out-of-my-recliner. An external speaker might help, but shouldn't be necessary. With all the digital signal processing going on in the radio, an AGC that works should be a piece of cake. Anyone else?
I agree with you 100%. The first message I posted on the Uniden forum was about the apparent lack of a working AGC.
I had just setup my new 436 and was scanning several local P25 systems. The scanner was working as I expected, then it landed on a TG with a dispatcher I could barely hear. Next a unit in the field responded to the dispatch that was so loud I had the same reaction as you. I jumped out my chair and reached for the scanner, almost knocking the scanner off of my radio table. The speaker splattered so badly I thought that I had just destroyed my new scanner in its first five minutes of monitoring.
The best part was that my GRE 500 scanner had landed on the same TG at the same time. While there was a difference in the sound levels between the dispatch and the field unit, it was
no where near as extreme as the 436.
I did go out and buy an inexpense amplified PC speakers, I think they were about $6 or $7 with tax. Using the external speaker works much better. There's still an overly large range of volume, but if I blow out the PC speaker I can replace it pretty cheaply.
But the point is I shouldn't have to do that. I sincerely hope that Uniden is addressing the AGC issue in it's up coming firmware update.
