- Joined
- Jan 15, 2007
- Messages
- 7,330
The latest firmware version is 1.2.1 how do you find out what changes where made to a Firmware?
The latest firmware version for the 436HP is 1.02.07
The latest firmware version for the 536HP is 1.02.03
How do you enable Priority scan on a P25 system?
I have entered the system, site, departments and talk groups with Sentinal. I selected one department/channel and set P-Ch to ON in the sentinal software and uploaded. All departments and talk groups are scanning ok. When I hit F-.no on the scanner, none of the settings for priority work. They return a result of Priority Scan - No channel.
How do you turn it on for one TGID on the system?
It's a little confusing, at least to me. I also got the same "Priority Scan - No Channel" message, so I asked somewhere in this forum. Upman answered it for me.
The deal is this: There are two different priority scanning "things" one for conventional frequencies, the other for trunked systems.
The Conventional one is set via the Profile Editor. It is in the Miscellaneous tab, General Options, Priority Scan Mode. You can change that to On or Off. If you select On, then there must be a conventional channel established to be the priority channel. If you do not designate such a conventional channel, then the error "Priority Scan - No Channel" appears.
On the other hand, Priority ID Scan for a trunked system is set differently. You need to edit the Favorites List containing the system. Then highlight the desired system in the left pane and click the "Options" tab on the right pane. You'll see a box saying "Priority ID Scan" with the options "On" and "Off". Choose "On". You'll then need to go to the list of channels and set the P-Ch to "On" for the desired talkgroup.
Unfortunately, that's the extent of my knowledge on this. Something I'm wondering about on this subject is "What happens if more than one talkgroup is set to be On as the P-ch"? That's as in does any one have a greater priority than another?
Hmm. When I set the conventional channel priority to off on the Profile editor, that error message ceased to appear.
Thinking wildly, do you have more than one profile involved? For example you could have Profile A in the scanner, but have edited Profile B but not sent Profile B to the scanner.
Thanks for the answer - the talkgroups I have on priority are all associated with the same quick keys, however.
I don't know if you do much with Alert Lights, but I thought I'd throw out the idea of setting the Alert Lights for a priority TG to fast or slow blink.
As luck would have it, I've got my scanner up and running as I type this. I held the scanner on a non-priority talkgroup and there was a transmission on what I set to be a priority talkgroup. It jumped off the non-priority when the priority channel became acive.
I have been able to edit in the sentinel and it shows that an edit has been made, but when I go to upload it to the radio, no luck
Anyone working on running Sentinel under Wine (either OSX or Linux), please PM me. I simply can't go through this many posts (I gave up after 35 pages) to work on something that most people on the list have no interest in.
