So what's the difference between the BCDx396HP Sentinel and Arc536Pro?
Sentinel is freeSo what's the difference between the BCDx396HP Sentinel and Arc536Pro?
Sentinel is free
ARC536 does certain things(cut, copy, paste) that can't be done in Sentinel.
ProScan can do everything ARC536 Pro can do, it's almost $20 cheaper, and it supports a number of other models.Honestly, IMHO, ARC536Pro was a waste of money for me. I like Butel products, but I find Sentinel to be my goto program for programming the HP and SDS series scanners. I can't even remember the last time I opened ARC536Pro.
To throw this out there, I find ProScan is becoming my favorite software for programming.
You need to use Sentinel to update the scanner's firmware and database.
ARC536Pro can download directly from the RR database (assuming you are a subscriber) instead of pulling from the weekly extract like Sentinel does. Probably no big deal most of the time, but if you are trying to monitor a new system that's being updated regularly on RR that's a nice feature. ARC536Pro also allows you to control your scanner from the PC.
I don't think you made a mistake if you purchased it. As others have pointed out, ProScan also can download directly from RR and has remote control, but honestly for *programming* I prefer ARC536Pro. Don't get me wrong; I love ProScan and have it running 24x7 controlling a number of Uniden scanners, but I find the Favorite List editor a bit clunky, so if I'm adding new systems I use ARC536Pro. ARC536Pro also allows you to assign LED colors and options (on/slow blink/fast blink) when you import from RR which I really like.
ProScan does the same except it's after the import so you can edit all the other system, department, & channel parameters at the same time.ARC536Pro also allows you to assign LED colors and options (on/slow blink/fast blink) when you import from RR which I really like.
ProScan Favorites Editor clunky in what way? We pride ourselves in making the best and listen to the users. I'm not so sure that's a fair statement. If you had emailed me to help make it better and I did nothing then yes it's a fair statement. We've done a lot on the Favorites Editor recently.
You can copy by highlighting a cell and right clicking. You can than select a number of cells using shift+left click or ctrl+left click and then paste parameters into your new selection.Sentinel does certain things (update FW, edit profile) that can't be done in ARC536. ARC536 does certain things(cut, copy, paste) that can't be done in Sentinel.
I'm not sure if that is the copying and pasting you were referring to, but a lot of people miss that is an option regardless.
