(Mainly a question for Upman)
Is there any internal difference about whether I'm using the 3-pin DC power or the standard DC power jack? Is the 3-pin DC power filtered for mobile use?
Currently, I'm using the standard DC jack (not the 3-pin) for my mobile power install. It's working fine but I'm hearing what I think might be some noise. (It sounds like fast, low-pitched bubbles.)
My power is positive to fuse-block and negative to chassis ground; but, I don't think my power connection is the problem, as my Icom V-8000 doesn't have this "noise" sound.
I'm monitoring strictly 860-869 Mhz on the BCT-15 so I'm curious if this is a normal issue with monitoring mobile trunks. I seem only hear this 'noise' when someone is transmitting thru the trunk. It's not continuous though - it happens randomly at various times. I can be idle, sitting in traffic and the audio sounds crystal-clear.
-Nick
-Nick
