BCT 396t Missing First Part Of Transmission
scannerjunkie
South Suburbs.
I was playing around with my 396t and now i notice it misses the first second of a transmission when put beside another scanner.for example i have the 396t beside my base scanner on the same channel and when they say "10-4".on my base i can hear the full "10-4".on my 396t all i hear is the "4" of the transmission.i remember this happening before but i cannot remember what setting i used to fix it.any info would be great.thanks.
ampulman
South Jersey
Is this system a MOT w/P25 voice? Try P25 waiting time.
Amp
walt991
That's exactly what is happening to me. I am monitoring a true P25 system so no such thing as adjusting P25 wait time. Its very annoying as sometimes I miss the beginning of unit numbers, addresses, etc. I noticed that the response time is immediate during the 2 second delay period when someone replys. But, it it slow to produce audio when the talk group goes active while scanning, or just sitting on hold. So far, I havent seen a fix for this..
Also-Just to add- I have a 396XT
Paul???
scannerjunkie
South Suburbs.
The channel i mostly listen to is a non trunked analog channel.i remember doing somthing to it before and it solved the problem.i was programming it and happened to have my base scanner on and thats when i noticed it.
UPMan
In Memoriam
Arlington, TX
If the channel has CTCSS/DCS, program it in.
If it doesn't, set the channel to CTCSS/DCS Search.
Either of these will disable the P25 Waiting Time for the channel.
DaveIN
Founders Curmudgen
West Michigan
Paul???
You say if the talkgroup is sitting on hold it skips the beginning of the comm? I don't have that problem at all using the XT on a P25 system here.
walt991
Exactly. I'm holding on a single talk group (Pure P25 system). When a conversation starts, my PSR-500 has audio before the 396XT. I constantly miss the begnning transmission on the XT.
Example- I can hear the PSR-500 audio- "911 dispatch to 762" On the XT I only hear"to 62" Now if the calling party answers within the 2 second scan delay, the audio is INSTANT on both the 500 and the XT with no delay, and the audio is decoded without any misses in audio. After the 2 second delay, if somebody starts to talk, I miss the very beginning of the transmission on the XT.
I tried the same exact thing using an analog channel, and there is no delay whatsoever. Both the 500 and the XT have audio when holding on a conventional analog channel.
I'm not sure if something is wrong with my XT, or if this is just the way it is. Should I call Uniden for warranty, or just return the the radio?
W2SJW
Senior Member
Northwest NJ
Does the XT have a battery save feature? Turn it off....
I never thought of that as well - I turned it off & set the XT to the Bucks County, PA TRS.
Flawless decoding on all of the P25 talkgroups - no delay whatsoever! :D
Now the big test will be next week - the Burlington County TRS here in NJ was my #1 offender for the issues mentioned in this post...
