ka3jjz
Wiki Admin Emeritus
It looks like all it takes to remedy this condition is the "fix" that is outlined in homer545's posting. I just did that to my BCT-8...and BINGO....the audio is now clear and it stops on Trunked Transmissions as it did before..and just as my other two BCT-8's do.
Step-by-Step Directions....
Remove power from the scanner. Remove the 4 phillips head screws that are found on the sides of the bottom cover. Carefully pull off the bottom cover...it might be tight and there are wires to the speaker that you need to be aware of...so take it easy..
Locate a small tuneable coil that is close to the center of the circuit board. It is silver in color and about 1/4" square. Examine the top and you will see the 'slug' with a small screwdriver slot in it. For 'insurance' purposes, mark the exact location of the slot...just in case you need to reposition it if you screw up. (Ask me how I know to do this....!!)
At this point you might want to position the scanner so that you can re-attach the power cord and be able to put the bottom cover back to the point where it might be close to its original position. You might find that when you do this, the scanner will work as when new....or...you might not. This step is just a bit of 'experimenting' and might give you an idea as to how far out of alignment it is.
Now...for the actual 'surgery'...with a small screwdriver, turn the slug in the coil 'Clockwise' a very small amount ! In my case, it was almost the smallest amount that I could move it...and still be able to say that I had indeed adjusted it. Now...attach the power cord again...and give it a try. You should hear a big improvement...this might depend on how far out of adjustment it was. You may want to give that slug another slight tweak...or not. The 2mm movement that was mentioned in the preceeding post is a good guide...I don't think I went that far....but the change was immediate.
My Wild A** Guess about this is that some of the components (a capacitor most likely) in the tuned circuit has changed value over the years...with time, heat, cold, etc. and has allowed that tuned circuit to become 'detuned'.... Since I am guessing (again!)...that your BCT-8 was working fine for a long time and then over a period of a few months, it got more and more flaky...that would mean that only a tiny bit of tweaking is going to be all that is needed to bring it back to 100%..
Before reattaching the bottom cover, let it warm up for a half hour...listen to the audio...bask in your new success, give a big THANKS to Homer545...then remove power, replace the bottom...and SCAN AWAY!!
I am sending a stack of Virtual $50 bills to Homer545 for this tip....and if it works for you, please do the same...!!!
Into the wiki this goes -- there seems to be a number of folks with BCT8s - surprising since it's such an old radio
Mike
