bct 8 remote control help
vans113
Tennessee
I need some help here I have a bct 8 im using a serial to usb adapter, I have all my settings matching each other on the scanner, computer, and the bct 8 software, but my problem is every time i try to use the remote scanner control. I get an error. That tells me It could not find it basically. Any body else have this issue? If so how did you fix it?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
A couple of steps here that weren't mentioned - did you load the drivers for the USB adapter, and check Device Manager to see what port was allocated? Keep in mind that the process is dumb - it can and sometimes does allocate a port that is already in use.
The use of Device Manager is discussed here..
Connecting scanners via USB - The RadioReference Wiki
HTH...Mike
vans113
Tennessee
Finally got it figured out. I was using a usb to serial cable adapter ( 1 cable) My friend let me use his cables a serial to usb cable and a female to male serial cable and it worked fine. mine was adapter all in one, and that's where the problem lied. So i ordered the cables he has off of amazon and all should be well =D
vans113
Tennessee
well back to square root 1 I ordered the cables they came in just like the ones I used and back with the same problem... I want to blow this thing up... Any more ideas?
