BCT15 and Alpha Tags sent to the computer.
RedPenguin
I have a BCT15 radio scanner and I know it supports Alpha Tags, but is there any way to send them to a computer and have an online scanner as if you were looking right at the scanner as some Unidens do with I believe Arc EazyStream, it will literally say who is talking instead of you always having to guess?
K9GTJ
Kokomo, IN
I have a BCT15 doing that here - http://www.scankokomo.com
I am using the ARC15 programing and virtual control software and have the virtual scanner up and running on a computer. (http://www.butel.nl/bct15/bct15.html)
I then use Stream Web Town - http://www.streamwebtown.com/index.php - to upload the scanner audio and screen capture the "Virtual Scanner LCD" to show the tags.
There are several threads to do this and it is simple to do. Any virtual scanner software to display tags can be used. I just had the Butel for programming so that is what I am sticking with.
wise871
N.W. Florida
Can you provide a link on how to do this. I'm interested.
squadman
Lebanon, PA.
Can anyone explain how to get this to work? I tried a couple different times and when I try and add the video I keep getting an error message.
