NorCalDiesel
I currently have a BCT15.. I use it exclusively in my truck with GPS and have it rather well programmed for the western coast of the united states as that is where I primarily travel for work. Because I'm always moving, GPS is real important and I spend a lot of time fine tuning coordinates and radii.
Has anyone had any problems getting the radio to pick up the coordinates as programmed. I have had a couple times that I have uploaded programming and it finishes, resumes scanning, starts L/O using GPS location and ends up with nothing to scan once it has locked everything according to what it thinks the GPS corrdinates are. I don't know if this is the radio or the GPS antenna, but if I reload the programming it usually fixes the problem. I have a large programming file built in Freescan that takes about 5 minutes to upload from the start of the upload to scanning after L/O. I am pulling everything off RadioReference including GPS coordinates using Freescan -> Import -> RadioReference and go from there.
I want to move to the BCT15X because the GPS support is more granular in that you can "locate" your groups as well as systems. But I want to understand how to manage this a bit better and maybe fix something that I am doing wrong. I have a lot of time in programming and have all the programming versioned in version control. If I have to make any changes I want to make them now so any advice and help is much appreciated.
Also, If I bought a new scanner should I move into the digital scanner age or stay with the BCT15X?
TIA and best wishes,
Pat
Pat
