BCT15 humming and no sound after turning on the scanner - HELP!!
Pyr8
Mandalore system :|]
I have a 15 here that has a bit of an issue.
When i turn the radio on initially i get sound for about 5 seconds, then it slowly fades away and is replaced by a very low humming noise. I have confirmed that it is not the speaker...same thing on the two headphone/external speaker jacks.
Anyone have an idea if what it is?
My initial thoughts are faulty capacitor/power supply!?
Any help would be appreciated!
jim202
New Orleans region
How old is it? You might be seeing an issue of bad or dried out caps in the power supply section
of the radio.
Jim
WouffHong
Jawjuh :)
Hum..
IF you really mean: BCT15:
Change the Wall Wart (try the one with your second BCT15?) and if it cures it, toss the old one ASAP - Some have caused fires. :-( - They bring new meaning to "Chinese Fireworks"! :roll: :roll:
Trying it on a DC source (car or 2 6V lantern batteries) will also verify Radio is OK . :wink: :wink:
Wouff
gaiaisangry.com
Pyr8
Not really sure...picked it up off of a guy for cheep.
Do you think its the power pack/AC adapter...or something on the actual radio?
Pyr8
Wouff
gaiaisangry.com
This is the only scanner i have at the moment unfortunately...otherwise i would certainly have checked already! ;)
WouffHong
Jawjuh :)
Hummmmm.... Mostcertainly a Wall-Wart problem.
Cool..
OK - saw that BCT15 x 2 thing.. :D :D
Well, any good 12VDC source should work - Center is + and even a Rat-Shack universal PS should work . (Not the Wally-World variety ones - Had some putting out 16 V on 12 V setting!)
Good luck - it's a great scanner!
Wouff
Pyr8
Cool..
Wouff
Just tested the adapter and I'm getting "19.81V" off it without it being connected to the scanner!
Pyr8
I think i solved the mystery and maybe one day this post will help someone out??? ;)
The adapter the guy gave me is the "AD-580U" (13.8V 700mA), however the correct adapter for the BCT15 = "AD-1009" (13.8V DC 750mA Regulated).
Is the difference in 50mA gona make a difference....thought it doesn't explain why this thing is putting out 19.81V YIKES!
CompuDoc
Middletown NJ
I think that you should use the regulated PS. The one putting out way more than the amount it is supposed to is probably an unregulated PS. Back in the day some people would run their CB off an external power supply. The power supply was always a regulated power supply.
Pyr8
ok....i got another power supply today and still no love!
I pulled each of the 13 capacitors and checked them for shorts and to make sure they are charging properly witch they seem to be (used a multimeter).
What i did notice is that one of the chips on the board seems to be getting very hot (see pic)
Anyone have any other ideas?
WouffHong
Jawjuh :)
Try finding the connector nside the radio where the 12 Volts enters and see if the "Radio Off" and "Radio on" voltages don't exceed ,say, 13 VDC, just for gits and shiggles.. ;-)
BTW I enjoy using http://qsy.us "Ham" interface to TinyUrl if you enjoy those tools.(eh' - Toys? :) )
73
Wouff
http://wouffhong.org
Pyr8
73
Wouff
I tested the non working unit with one that does work and this is what i found:
(working radio) = With the radio off it reads 16V - with it on it reads 13.5V
(non working radio) = With the radio off it reads 16V - With it on reads 11.8V
Ideas?
