Blackink
Hello there. I would like someone's opinion on how I've set up a conventional system in my new scanner using Freescan.
The reason is trying to assign quick keys to all the "Groups" in the "System" Here is some info to give you a better understanding of what I'm working with.
Scanner-BCT15X
Software -Freescan
Location-Washington County, Vermont
Washington County, Vermont (VT) Scanner Frequencies and Radio Frequency Reference
I set up my scanner importing info from the RR database into Freescan from the above link location. I labeled this Conventional "System" as "Wash. County" with a system quick key #1. Freescan labeled all 11 of the cities and towns associated with Washington County as "Groups". There are 11 cities or towns listed in the Washington County area database that are labeled as Groups in Freescan.
So if I leave that set-up as is, which seems to be scanning properly, is that the correct way to set up my scanner for that conventional system? With that lay-out?
And if so, how do I assign "Group Quick Keys" to 11 groups when I only have the option of assigning 10 group quick keys 0-9? This scanner is capable of having 20 groups per system, you'd think I could assign quick keys to them all in Freescan but I can't.
I feel as though I may be setting this conventional system up incorrectly.
Thanks for any help,
Steve in Vermont
Scanner-BCT15X
Software -Freescan
Steve in Vermont
