After reviewing and re-reviewing both the "Easier to Read" and Uniden user manuals for the BCT15X, I think I've successfully programmed all the trunked and conventional systems and groups correctly. However, the scanner doesn't seem to "scan" all the systems. The S/O line in the display showing the active quick keys only has the system scanning (i.e. "flashing") on # 1. All the other programmed quick keys are displayed, but they don't "flash" nor do the system/group alpha identifiers appear as though they're being scanned.
This has to be something that I've done as the systems that were programmed by the vendor from whom I purchased the scanner scanned perfectly. After my programming, those systems are still there, but only # 1 appears to be scanning. I've double-checked the lockout features on all systems, groups, and channels. I've also utilized another scanner to confirm that during active incidents, the bct15x is, in fact, not scanning/receiving the active channels.
After the long process of learning the programming, my frustration factor is high as I believe that this is something very simple that I'm missing.
