Bct15x help
fireguy810
I have a Uniden bct15x programmed with a conventional system and multiple Motorola type 2 800 systems. When scanning the 800 systems the scanner locks on to the control channel and shows a full signal on the signal meter in the upper corner of the display but it seems to be only tracking one side of the conversation or sometimes only parts. When it's scanning it appears that the signal drops out momentarily. Almost like the priority scan is on and it's checking the priority channel, but it's not. I've checked everything I can think of. It's firmware version 1.03.
Any ideas?
I have a bct15 programmed with the same system and I have no problems.
sspo10
Georgetown MA
Fireguy810, Did you check your weather if programed in it will act like priorty scan is on.I had this happen to me when I programed my BCT15X just a throught?
