safetyobc
Just curious if a 15x or 996XT has a way to lower the volume of the weather alert. It is SOOOO loud. Too loud!
Hopefully this will not wake up the better half when there is a amber alert @ 2 am. ;-)
When I am sleeping and the scanner is 2 ft away from me I don't need it screaming full blast to awaken me. It isn't a Uniden or goverment responsability to assure that we can hear the alarm, if it was then the weather alert function would always be on. It is the responsability of the user to assure the volume is appropriately set for the situation. I have chosen NOT to use the function just because is it can't be adjusted to an appropriate volume. I am sure many others have taken this stand also! So Uniden, what good is the weather alert function if people choose not to use it? As I understand it, and I may be in error, our scanners ARE NOT required to have the volume of the alert at full blast. I have been told this is a manufacturers decision. Uniden, give us the option, and there-by we accept the responsability, of lowering the volume!!! If I have been informed wrong please let me know, Thank You.The weather alerts on all scanners are at a set level so someone will not have it turned down and miss something that could save a life.
To market the scanner as an alerting device, they have to comply with the CEA specifications for both RF decoding and aural alerting.
We adhere to CEA-2009-A specifications which call for a minimum 77dB at one meter within the range of 500 to 1500 Hz.
We consider All Hazards Alert to be as critical as your smoke detector in its ability to rouse you from near death to take action.
It is loud infact its almost 95 DB at 3 feet (measured with a chaep radioshack sound meter) being loud enough to wake you is fine but being so loud you are deafened and cant hear the alert is another.
perhaps uniden would concider a hidden menu adjustment for this feature along with a warning along the lines of "adjusting the alert from the preset value will void the CEA compliance and/or warrenty for that unit" Uniden can cover thier "butt" by adding a digital marker in the unit memory showing that the level had been adjusted thus releasing them from any action.
There is a way to change the WX alert in the firmware, but you need to figure out how to download it, change it and upload it back to the radio.
Of course I would and I am sure others would also. For me it would make the alert functional as I refuse to have it 2 feet from my ears while I sleep and have it go off full blast!!! Uniden could clearly make it mentioned in the on-screen set-up function (do I have the correct terminology here?) and in the manual/CD that modifying the volume would release Uniden from any responsability. How good is this function if people refuse to use it? It is only a good marketing tool. I am reaching back in my memory now and I don't have the time to read alot of postings from the past, but didn't someone mention that Uniden wasn't required to make the alert that loud but decided to do it anyway? If they were not required by law to do so they would be serving their customer base very well by addressing this concern so we/I could make use of this feature.I assume that all of you that want it less loud would be willing to indemnify Uniden as to any lawsuits and resulting judgments that it might sustain as a result of making it less loud, right?
When there is a safety standard and a company fails to comply with the standard, liability often follows. Uniden appears to be smart enough to not do that.
Dick
I certainly would have no issues protecting uniden against action. The only way I can see for uniden to proactivly protect itsself would be to do as I suggested, make the level adjustable but also set the software to "mark" a memory location so that it can be shown that the level was adjusted from the factory level (no mark= un modified). We use this method in our software it lets the end user make changes they want but releases us from liability (the mark is write only and cannot be changed back).
KE4ZNR you are right although it would be nice to be able to edit the firmware , there are lots of changes I would like to make.
I was thinking along the line of my not holding Uniden liable for for a loss I incurred because of my not hearing a warning because I turned the volume down. Of course in this world it isn't that simple. The probability of others using the legal system to bring an action against Uniden is far from remote.You obviously don't understand the concept of indemnification or you lack good judgment. From what you say you'd be willing to agree to pay all legal fees and judgments that Uniden might incur as a result of making the change that you propose. Unless you have no assets, that would be a pretty foolish thing to do and, if you have no assets, your indemnification wouldn't be worth the paper it was written on and Uniden would be foolish to rely on it.
Dick
