BCT15x Question
Grove City, Ohio
Good Day All!
I just got a BCT15x, and for some reason it doesn't lay flat. It will spin like a top, was wondering if anyone had this issue? Was thinking I may need to exchange it. This is my first new desktop scanner that I have purchased in a long time.
Thanks in advance for any advice,
Steven
cpuerror
Ontario, Canada
I'm not sure if I'm really clear on what you are asking, but do you have the mobile mounting bracket attached? I use some doublesided tape to keep it in place.
ModelTrainGeek
This is the model I'm thinking about buying... Are there rubber feet on it? Possible one missing? Or, you could add some of your own.
Grove City, Ohio
I didn't see any in the box, but after searching around the net, I found out that there should have been some in the box. I found some at work, I am going to try that.
On another note, so far I am happy with this scanner, I usually go with GRE/Radio Shack - so there is a learning curve for me, still learning how the menus are setup.
Grove City, Ohio
Radio Shack sells nice little rubber feet about 3/4" square, and about 1/4" tall. They will keep it from sliding, and also raise it up enough to allow the internal speaker to work.
Cool, thanks for the link, those are better than what i have here. Will be stopping there to pick up some.
w2csx
Rochester,NY
Mine was tucked inside the extra box with the screws and stuff, they are about 1/4 inch square.
K7CAR
Monroe, WA
Mount the mobile bracket upside down and you can tilt and adjust the scanner to your liking. If you're on a slippery table top, add a piece of double back tape if you really like to push those buttons.
