BCT15X Rear Serial Port Question
sfreiman
Tucson, AZ
Can the serial port on the back of the BCT15X be used for programming/control instead of that jack on the front?
eaf1956
Evansville, IN
Rear Port
Yes, However, you need a NULL MODEM cable to do it. You can CONTROL and update using FREESCAN or ARC. Be AWARE that FIRMWARE update MUST be done via the front port. I took my feed offline and used FREESCAN and ARC996 both with my 996T and it worked fine via the rear port. Note that I use the rear port for feeding tag information to radio reference.
eaf1956
KC9LVX
Also, be sure to check your COM port settings.
sfreiman
Tucson, AZ
I just want to program/control using ProScan via that back port. It so darn hoaky having that cable plugged in the front. Never understood that design decision.
W6KRU
Oceanside, CA
Install it in your dash and attempt to update it using the rear port. It will make a little more sense then.
eaf1956
Evansville, IN
Din
OMG you mean they still got cars with DIN radio slots? Couldn't put my 996T in my car dash if I wanted to.
I used the rear port for ONLINE control and programming on my 996T I assume it is the same with the 15 you just need a NULL Modem cable. Note: When I first tried feeding TAG Ingo from the rear port I bought a F-F rs232 cable and it didn't work. Went and got a M-M Null modem cable (it was all they had) with 2 gender changers and it worked fine.
BTW: I tried actually doing this before I replied so I know it works on the 996T
KC9LVX
eaf1956
Evansville, IN
Rear Port for TAGs
I just wanted to ADD that the rear port has to be activated in the FIRMWARE. Just go to SYSTEM SETTINGS and set BAUD rate for both Front and Rear ports
Kennrth
Bay Shore Long Island NY
I'm not sure that a full null modem cable is requred but I am sure it will work. I make my own cables and just swapped pins 2 and three and works for me.
Full Modem Cable -
6 6 DSR
I think you can get away with this on DB9 connectors, Sheided cable just pins 2,3 & 5 Signal Ground, Pins 2 to 3 and 3 to 2 and 5 to 5
K4APR
Chesapeake, VA.
Full Modem Cable -
6 6 DSR
A basic null configuration is just pins 2 and 3 swapped on one end. A full null config is needed these days, unless flow control is being used.
sfreiman
Tucson, AZ
Used a serial cable I had laying around with a Null Modem and F to F adapter. Seems to be working fine to control the BCT15X via my ProScan software. Thanks all for the info!
eaf1956
Evansville, IN
Super
Thats SUPER...Glad it works for you!
KC9LVX Evansville, In Feed
cifd64
Northern Passaic County, NJ
OK, so my birthday is coming up and my Fiancee is feeding my need for mobile solutions. Do you recommend the 15X? Installed in the dash and all that. What software should i use for progging and such. I have never had a scanner in my truck other than a handheld, but want something a little sexier. What do you think.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
We don't know where you are (county/state will do), so it's hard to know whether the 15X would do the job for you. Some areas are using digital trunking and that's something that scanner cannot handle.
Please go up to the User CP (which is under the thread title) in the blue toolbar, click on that, then hit Edit Your Details, go about 2/3 of the way down for the right box to enter that stuff.
As for programming, go get FreeScan which is freeware (you can always go to ProScan or the ARC modules - which are paid packages - later. But this is more than good enough to get you off the ground). The user guide is hosted in our Wiki, which I'll get to in a moment. You will also need a USB-serial adapter, as most PCs these days don't have serial ports.
Our wiki has an enormous amount of information about this, DMA (which is dynamic memory allocation, the way Uniden scanners allocate memory - assuming you're not familiar with it) and trunking in general. Under the Scanner Master ad, in the blue toolbar, float your mouse over Wiki then select Wiki Home. Links for all those topics, and much more, are found here.
73 Mike
garys
Northern NJ, NYC and Long Island
If you want to listen to Jersey City, you need digital. NJSP is analog, as are NYPD and FDNY, including EMS. I think LI is still all analog. If you go to CT, you'll definitely want something with digital capabilities. If you go down to Somerset County, Edison, East Brunswick, and that area you'll want digital, although some of the PDs are encrypted.
Hope that helps.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As this is the Uniden forum, the BCD996XT is the way to go here. You might save a few bucks by going with the older 996T, but from what I understand, the digital audio recovery isn't quite as good as the XT model.
And by the way, FreeScan works with both 73 Mike
