bct15x Recording
Colton25
I have just started a live feed here on RR and i have a question about my new bct15x. I would like to only record 1 channel for the feed but at the same time scan as normal. Is it possible to only set 1 channel to be recorded and scan all the others at the same time?
cg
Connecticut
It should work fairly easily.
Every System except the one with the target channel needs to have the Record option set to off (or record Marked Channels). Every channel in any bank using record "Marked Channels" needs to have "Record" unchecked.The target channel has Record checked.
The "record out" jack on the rear of the radio goes into the feed. Test by plugging a speaker into that jack. Record out jack usually has a set volume level so it may not be able to be controlled by the front knob.
The downside is that any traffic on the channel for the feed will be missed when other channels are active. You may set it as priority to ensure no missed replies over the feed.
chris
cg
Connecticut
It sounds like the System is set to RECORD ALL. That is in "Edit System Options" for each system. Set to "Marked Channels" under record options. Then set the record on your one channel to "On" with all the others to off.
If it is a trunked system, the TGID needs to be set to record.
chris
