Can someone check my BCtools file and see if I have evertything set up ok to get the most out of PPD and MCSO?
There dosen't seem to be anything in the file. Should it be a .zip file or a .bct file?Can someone check my BCtools file and see if I have evertything set up ok to get the most out of PPD and MCSO?
I still can not open your file. Take a look at the listing here http://www.radioreference.com/apps/db/?sid=2508Yea thanks I figured that out! If anyone else can check it out and let me know if the talk grps are good? I do pick some up on PPD that arent on the list on this site. Where can I find an updated TG?
Mesa uses their part of the system more fully than Phoenix. I doubt you are in an area where you can receive Mesa's Simulcast D. Gilbert and Mesa are mostly on there with a little on Thompson Peak. (Thompson Peak has separate systems on it, County and Mesa, not to mention CAP so be careful not to get confused as to what you're monitoring.) If you manually tune through the Simulcast D control channels, do you hear the same type of audio as you hear on whatever active control channel Simulcast A is using? If your scanner can't hear and decode Simulcast D's control channel, the voice audio isn't going to happen. Only a very few Mesa talkgroups operate in Phoenix, just as only a few Phoenix talkgroups operate in Mesa.I do, thanks! How come I never hear any traffic on Gilbert or Mesa are they not using the system yet?
