Bearcat 20/20
fortis
Labrador City
Hello
My organization uses an old scanner called the bearcat 20/20. It is no longer functional and requires a replacement. I am entirely ignorant on these matters and would appreciate some guidance.
It is for an aviation use and needs no more functionality than the old scanner. With a small budget in mind, please recommend a useful replacement.
Thanks in advance
Shannon
edkt4hr
central kentucky
air band
radio shack has some low end scanners that do aircraft .i would check their web site for specs . you need one that pick up 118-136 mhz .check for it your self because some radio shack zombies don,t know any thing about scanners
mattl3320
pa
The radioshack pro 405 base scanner covers the airband and sells for around a 100 dollars check area stores near u my be on sale.
W9NES
Indianapolis,Indiana
fortis, You can find a good programable scanner that will cover the air band on Craigslist. Any scanner that covers the airband 118-136Mhz will work for you. I use a Regency 16 channel aircraft only programable ACT-T-720.I got my Regency off of E-bay.Please send me a pm and I will check to see what I have or you that will cover the airband.
