CobraJockey
I just bought a new Bearcat 980 SSB, we will be moving to a semi-remote area hill-top and I want to use it as a SSB/CB base station for emergencies and skipping, instead of as a truck mobile. I've been out of SSB and HAM for a few decades, so we're looking for some Experienced advice on what to buy. The Specs for the 980 shows it needs a peak 5A 12VDC (13.5V) service. But I'm not sure just how "clean" or regulated a power supply it needs to be??
Can I just use a good rated 5A 12V power "Brick", or should I invest in a nice variable Amp and DC Voltage "Bench Power Supply"?? Is that over-kill for a small SSB radio like this that only puts out 4W on CB and 12W PEP SSB??
I found a couple examples I'm considering on Amazonie -
A Bench Lab level DC Variable / Switching 0-30VDC/-10A (I can use it for other bench repair work)
or - a more simple AC to DC 5A Power Brick with over-current protection?
Or, something in between? Got suggestions you're using? I'd like to stay between $20 to $50
Thanks in advance for your advice!
