Bearcat Uniden BC250D Sounds like robot, why?
Patrol1j
Niagara Region
I put in the local police for Niagara here and they sound like robots, can anyone tell me how to tune this up to work? I am running a Uniden Bearcat 250 with Apco 25 card installed and working.
Joe
AZScanner
Somewhere in this room. Right now, you're very col
Joe
You have to tweak the voice setting. In conventional manual mode, wait for a channel to go active and then hold down 9. Once you're in the sound quality setting, let go of 9 and use the thumbwheel to adjust the 3 values that appear. There will be a 4 digit number displayed on the first line of the LCD when you are receiving a transmission - you want that number to be as close to 0000 as you can get.
Hope that helps.
-AZ
BLAZER99
When you hear a transmission on the channel, press "Hold", then press and hold number 9 until you see "Sound Quality" on your screen. When it starts transmitting again rotate the VFO / Select knob to the left or right to adjust the quality of the sound. When you get it where you want it, press "Resume" twice or "Resume" and "Scan" It does tell you abut this in the manual.
I have the BC785D (base model of the 250D) and I had to adjust my digital sound quality. I have never gotten it to where it sounds like a regular VHF or UHF system, but a least I can understand what they are saying. It sounds a bit muffled and also, the volume of the transmissions is louder than regular systems.
Hopefully Uniden has corrected this problem in the newer BC 796 and 296 models.
Forts
Ontario, Canada
Yep, NRPD is full time encrypted. No amount of audio fine tuing will help that I'm afraid :(
Saint
Fort Erie Ontario Canada
re-NRP
:cry:
Also the Niagara Falls Parks Police are encrypted too.
Steve
