bearcom bc 10
oliver1
hello i need more information abouth the bearcom bc 10 ,
works on vhf ??
how to programm it ,
or what frecuencys have this radio
programing cable and more
its a 4 ch radio very good working but i need some help to undertand becouse the manual dont say much abouth my questions
some help will be apreciated
thanks
alphacommnj
Gillette, NJ
Bearcom BC10 Radio Information
Hi oliver1,
Check out Bearcom's website for some specific information on the BC10 two way radio.
BearCom BC10 (VHF/UHF) from BearCom
Looks like this radio is available in UHF or VHF so you will have to get a hold of the software from Bearcom or read the frequencies with a scanner to confirm yours is VHF. This radio was custom designed and rebranded by Bearcom (manufacturer is unknown to me). The side accessory jack is a standard Motorola 2-pin jack and accessories for the CP200/BPR40 will fit well with it.
alphacommnj
Gillette, NJ
After doing some quick research I believe the BC10 to be a Tekk X100 radio, with a new screen cover and some minor detail changes. Take you battery off and see if it says Tekk XU-100 or XV-100 (for UHF or VHF) and you can order the programming software and cable from Tekk directly.
A quick note: the fact that Motorola 2-pin accessories fit this radio is not an indication of it being a Motorola radio. My speculation is when this radio was designed by Tekk it included the side accessory layout of common Motorola radios to make transitioning easier (from Motorola to Tekk) and bring in more end users to try it out, save money on the physical radio, and save money by using the same accessories.
Alexander
