BearCom IC-F21GM/cs-f11 compatibility
w7ees
Hillsboro, OR
I have 8 BearCom and 6 ICOM F-21GM's on the bench and I find the CS-F11 software doesn't like to talk to the BearComs. The CS-F11 adjustment software works fine with the BearComs though. Any suggestions? (Trying to sync all of them.)
(WQRW723)
Make sure the CS-F11 is the latest version. Sometimes older software will not talk to newer radios. I had this issue before and a newer version of the software fixed the issue.
You can have mixed results contacting Icom to get the software update. Try giving them a call and explaining the situation. Telling them you have a legal copy of the programming software usually helps.
