BEE00.966 P25 control channel on 173.5875MHz
west-pac
Do you guys have any 173MHz frequencies in use in Ontario? I saw a BEE00.966 P25 control channel on 173.5875Mhz, and I can't figure out where it's from.
Saint
Fort Erie Ontario Canada
You don't say were you are I don't know if this helps you, down in Fort Erie I pick this up
173.5875 NIAGARA FALLS AIR BASE EMERGENCY FIRE CRASH PLANE MAINTENANCE NIAGARA FALLS NY 293 NAC P25E
west-pac
I'm in northeast Indiana, USA.
As far as 173.5875MHz, that freq is used at a lot of air bases, however, one of them is using it as a control channel for a whole P25 system, instead of using it as a simplex P25E channel. I'm trying to find people around the Michigan, Ohio, Indiana, Illinois area to give a listen to that freq to see if they can hear a control channel. That would narrow down where it's coming from.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
You can rule out .5875 in Ontario's VHF Hi Band. That frequency spacing is not in line with 15 kHz spacing we use. It would be 173.58 or 173.595
One from your side I believe.
ecps92
Taxachusetts
since it is likely US FEDERAL, you may want to ask the moderators to move one of your Mult-State postings to the Federal forums for one-stop shopping
