I don't use Win97, but I did import the BWI stuff via FreeScan, and it worked fine. All the approach/departure stuff is under the Potomac TRACON, just as it should be - both milair and commercial.I Know that the frequencies are there and i have looked at them. I guess what im trying to say is that when using Win 97 to import files from RR it breaks it down to conventional or trunk. Then country,state,county and agency. When you do this it don't show the milair frequencies and give you the option to import them.
That specific example shows up in Win97:I don't use Win97, but I did import the BWI stuff via FreeScan, and it worked fine. All the approach/departure stuff is under the Potomac TRACON, just as it should be - both milair and commercial.
If you don't see that, then a note to Don is in order. There's no database error, as far as I can see. 73 Mike
