Ensnared
For the first time in a very long time, I heard Bell P25 loud and clear in the afternoon.
I don't know of for sure but I think the P25 simulcast system antennas may not be set at high locations but more antennas at lower locations through out the county. Remember its is a P25 simulcast system so the EDACS would be the primary system and the P25 is used a simulcast.
Try changing the filters used on that system (on the SDS100). I've seen several comments that Invert or Wide Invert has helped on certain systems, but the filters are often more specific to the system and your location. On more that one occasion, I've seen comments about two or more users, monitoring the same system but not at the same location, using different filters to improve reception.Sooo......
436 vs SDS100
On this system..can't even compare.
Seems like the SDS is still missing a good bit but not nearly missing as much as the 436.
Anyone else trying to ID the many Unidentified TGs on this new System..
Seems like most of them are following the format from the old system
50xxx
or 5xxxx
Seems to be a small site with 2 Chan mainly in use by SO.
I don't get a signal on the North side of Killeen. Under a FCC search three frequencies in the 700 MHz band is Licensed to Bell County and listed as 100 watts. I assume its interop patch and listed on under SO groups since the SO is the highest Law enforcement in the county.
