Does anyone have a list of all the EMS control channels for Northwestern Ontario?
59258 said:Does anyone have a list of all the EMS control channels for Northwestern Ontario?
Mike_Oxlong said:The EMS doesn't have control channels.
The control channels belong to the Fleetnet system and are shared by all agencies.
Take a look at the other zones. The control channels are common across all 4 zones.
warrior420 said:All data comes through the control channel and your scanner decodes it. You can put more than one control channel in one system. When you are out of range from one it will pick up the next one in the list. When your scanner is set up for conventional it has no idea what to do with control channel data, only when setup correctly will it decode properly.
59258 said:Thanks, so I clear I can put every control channel listed under zone 4 into one truked systm and then just search ID??
G
