Belleville / Northumberland monitoring
TD
Hasting County
Hello All
Just wondering if there is anything good to scan in Belleville and Northumberland Ontario
Enjoi19
Plenty of fire departments (Port Hope and Cobourg require the DMR upgrade), the usual OPP and EMS talkgroups. I've never tried scanning there but CFB Trenton is fairly busy with air traffic often, lots of training exercises.
Here's some relevant database pages to browse.
TD
Hasting County
I've just moved to the Belleville Ontario area and I do have a new discone antenna. I have an older scanner, I use BCD396T.
mciupa
Moderator
It wouldn't hurt to try and program some New York State frequencies either. Monroe, Oswego, Jefferson counties. You may be surprised with what your discone will receive.
mciupa
Moderator
From the looks of things:
Belleville
FrequencyInputLicenseTypeToneAlpha TagDescriptionModeTag
142.035RM293 NACBPS1 - DispatchPolice Ch. 1 - DispatchP25ELaw Dispatch
143.115RM293 NACBPS2 - DispatchPolice Ch. 2 - DispatchP25ELaw Dispatch
139.770M293 NACBPS3 - Simplex/TACPolice Ch. 3 - Simplex/TACP25ELaw Tac
149.495BM110.9 PLBPS/BFD/BT LiaisonPolice/Fire/Transit LiaisonFMInterop
169.845162.300XJH67RM412 NACBFD Stn. 1/2Fire - Stations 1 and 2P25Fire Dispatch
154.265XJH518BMBFD Stn. 3/4Fire - Stations 3 and 4P25Fire Dispatch
Police NO and Fire YES.
Guccisock5
What are you listening to and what type of scanner you using? What type antenna you using?
Currently using an HP2 & Radio Shack Pro-94. At home, I just have a Diamond telescopic and in the vehicle I have a pretty cheap wideband antenna.
Picking up OPP Zone 2, many fire departments as far as Trent Hills, Rail, Air, Public Works, Military, just to name a few.
scanfreqer
Scanfreqer
Barrie,On,Ca
I used to live in Madoc and worked as a printer for the Belleville Intelligencer, but I remember picking up Rochester in the winter time. There is not much around there so there is not much to listen to. Everything is spread out.
Guccisock5
For whatever reason, I never pick up Belleville Fire Station 1 and 2 through the RadioReference database. Earlier tonight, I picked up Station 1 through a random NY State freq (150 range or something). Even Station 3 and 4 via the RadioReference database comes through sometimes as if it’s encrypted, not sure why?
randyf
still trying to figure this all out
campbellford ontario canada
Hmm, I can here Fire in the clear here on 169.8450
