Belmont county
mg463
Ohio
Why is Belmont County trunking not coming in on my pro 106 anymore ?should scanner be on splinter or rebanded ?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Rebanded.
In your TSYS object, set T TABLES to CUSTOM. Then edit tables 1 and 2 to be:
Code:
          Lo Chan   Hi Chan    Offset        Base Freq         Step
Table 01:     440       559       440       851.025000       25.000
Table 02:       0       719         0       851.012500       25.000
If you are using a program such as Win500 to program your scanner, you need to make sure you set Trunking Tables to Custom and then click on the "Trunking Tables" button and select "Rebanded" and save it all.
Mike
mg463
Ohio
Belmont County
Okay Mike thank you I'll try that !!!!!!!
