In your TSYS object, set T TABLES to CUSTOM. Then edit tables 1 and 2 to be:
Code:
Lo Chan Hi Chan Offset Base Freq Step
Table 01: 440 559 440 851.025000 25.000
Table 02: 0 719 0 851.012500 25.000
If you are using a program such as Win500 to program your scanner, you need to make sure you set Trunking Tables to Custom and then click on the "Trunking Tables" button and select "Rebanded" and save it all.
