Belt Clip Hanger Broke?
ScubaJungle
West Central Florida
The little circle clip Hanger on the back of my BCD436HP seems to have broken off. The screw does not hold in place when I tried putting it back, and falls right back out. There was a small amount of black plastic around the base of the screw that seemed to be from the Hanger piece. Is there a way to fix this - use a longer screw or something, or can that damage the scanner? I guess the best bet would be to get a case with its own clip, but I liked being able to clip it to my shorts when in the house.
jonwienke
More Info Coming Soon!
VA
A new button won't solve a stripped hole. And a longer screw will damage the circuit board.
Get the scanner master case. It's way sturdier, the belt hardware is all metal.
greggk
York,PA
I don't see any easy fix here except as others have said: buy the case from Scanner Master. They have several grades, but I recently purchased the hard leather case and its strong as can be. Good clip on back as well. Greg
