Bendix King/ GMH Scanning Issue....?
dustyboots
Hello everyone,
So I am coming across an issue I haven't dealt with before. My mobile GMH will not scan. I am able to select scan channels, upon pressing scan the arrow above appears but isn't flashing. My assumption is that this might be a global setting issue but not positive. Any ideas?
n0nhp
Grand Junction
Ground the button on the back of the mic. (or make sure the monitor wire to the button is good).
It has been a while since I played with a GMH but I seem to recall that there was an accessory jack on the back panel that you could put a semi permanent ground loop into so the mic hanger didn't have to be grounded.
Bruce
dustyboots
Thank you for the heads up,
I spoke with Relm tech support, and they confirmed this in the global settings. They also mentioned the off hook scan setting would create this and the global setting needed to be on high. I'll try to see if there is any grouding issues. Thank you again.
