so when they start up I should be able to hear something ..I think it will be soon...thank youThe Warsaw site is southwest of the city if I remember correctly.
ok..Thanks for you helpTheoretically yes. That depends on if there an affiliation to the Warsaw site. I suspect something would likely be affiliated to that site full time but it’s hard to say. I’d say your best chances of hearing them IF they go onto MoSWIN would be the Warsaw ajd colecamp sites. One of those two sites should have something affliated to them. Assuming they bought/have proper multinad radios
Im not sure what you mean by P25 conventional ...could you explain?I did some further checking on this. From what I was told by some techs there has been no indication of Benton county moving to MoSWIN. It’s very possible they may be moving to their own P25 conventional. Apparently Henry county will also be moving to a P25 conventional repeater system.
ok so how would I program my pro 106 then..leave it the way I have it ? I'm at a loss now. I have the Benton county ID's programed in...IT sounds like the radio tech's are working on the analog side of things today..P25 conventional would just be a standard P25 repeater. Non trunking.
tones yesDoes the scanner allow you to set tones. Or select analog/digital audio types. I’m not familiar with the radio shack stuff.
under settings it does scan for NAC Right nowIs there anything under tones that says NAC? If so that’s how you can PROGAN P25 conventional. Right now since they’re on analog you could just mouse around the scanner or computer software. That way when or if they go digital you can then figure out what to program.
