Benton County
garybruce
Ripley, MS.
I have been monitoring in "open mode" that has allowed me to tag Tippah & Union counties now using P25, but after 2 months in open mode still cannot tag Benton County even they are on MSWIN.
Any idea's?
Avery93
Marion County, AL
Do you have a Phase II capable scanner?
If no, then It's quite likely they are using Phase II. A Phase I only scanner will not even attempt to follow a Phase II channel grant, so you won't even know when a Phase II user is active.
milf
Careful, I CAN hear you!
Indianapolis, IN
The only way to even know there is Phase 2 activity with an Phase 1 only scanner is when running Pro96Com or Unitrunker etc.... And seeing it on there.
garybruce
Ripley, MS.
Thank you for the quick replies.
Not sure if it's Phase II capable, it is the BCD996XT. This unit is capable of MHP and all other surrounding counties Sheriff's on P25 I or II??? You could be on to something, but wouldn't figure Benton County Sheriff would be different than all other North Mississippi Sheriff departments.
Maybe school me some more on how to go from here (in layman's terms please)
garybruce
Ripley, MS.
Benton County Sheriff was received on my 996XT last Friday, so they are not on phase 2. Looks like I figured correctly.
milf
Indianapolis, IN
Again.. sigh....
By January 2017, which is only 2 years away, the ENTIRE MSWIN will be pure P25 Phase 2 as planned currently. So anyone using Phase 1 currently, will be switching. Just point in case: Any system using 700 MHz must be Phase 2 compliant by 2017 unless they obtain an waiver from the FCC. LWIN, and AWIN are two I am aware of that have such waivers to delay implementation until 2020. Now you know.
garybruce
Ripley, MS.
Regardless what happens in 2 years, it is valid current day. So in an effort to support the local Scanologists, they are on TG# 50727
milf
Indianapolis, IN
Added, and all db's updated accordingly. Nice catch, and hope ya'll catch the EMA, FD's etc...
KE5TLF
MS Gulf Coast
At the top of every applicable RRDB entry
APCO Project 25 - The RadioReference Wiki
You'd figure wrong. Every county makes it's own purchase/choices, but in the end EVERYTHING will be Phase II by, or before, 2017.
Again.. sigh....
.........and as of 7 days ago, all a moot point now. Not to say some/most/all? won't anyway, but there's no requirement to do so now.....
milf
Indianapolis, IN
That will save a lot of money for future gear.... Too bad about whatever is already in the pipe eh?
KE5TLF
MS Gulf Coast
Yeah, no, maybe? Could at least save the DMR a boat load for a while anyway. (pun intended). I guess it remains to be seen what policy changes, if any, the WCC makes now.
