Berlin FD's Tones
lightningx54
Feed Provider/Amateur Radio Operator
Does anyone know what Berlin FD Tones are? I know that in Berlin we have four depts, Berlin, Kensington, South Kensington and East Berlin. All Berlin FD's is on 154.3400 and PL 82.5. Or does anyone know of a free program that can decode them?
joehawth
KB1RRG
Morrisville, Vermont
I'm not sure exactly what you need... There is no need to be decoding PL tones, especially if they are all using the same tone...Just tune your scanner to 154.3400, and you will hear all local traffic, regardless of PL tone. THe only reason you would want to use a PL tone on your end was if you needed to filter out other transmissions on the same frequency that you dont care about.
This is the correct frequency according to the DB, and there would not be any type of digital system, trunked system, or encryption on that frequency. SO, with a scanner set to 154.3400, you should hear all companies in the Berlin FD no problem.
lightningx54
i knew that about PL tones. I'm looking for the pager tones.
CT22
Banned
CT
joe, your a ham? You cant even understand a simple question?
I can tell you from listening to them that they are probably Motorola tones. Do an internet search for Motorola QCII tones and that will give you a good place to start.
lightningx54
thanks, ill compare this to my recording.
lightningx54
That is kensington's tones. thats my company. Theres 5 sets of tones. for east berlin, kensington, berlin and south kensington and the 'all call" tone.
I have this for Berlin:
341.8
421.6
cg
Connecticut
Perhaps someone in your departments has a newer Uniden scanner. They can be set up to read the alert tones. Also you can check with the radio service that works on the department radios.
chris
