Hello,
I just downloaded the csv folder (Quebec, Capitale Nat) from the site, but when I am on CHIRP and want to open or import the csv folder, it gives me an error message (see image below), Anyone got a solution? thank you in advance for your help
In case someone else has same issue. This is happening because you are trying to load uv-5r data file in bf-f8r. Try loading data from the radio first, then make your changes to that data file, then you will be able to upload it back to the radio.
