yycwrangler
- Joined
- Apr 10, 2016
- Messages
- 24
Hopefully I can be specific enough that you guys can give me a brand and model.
Using a HT (for listening) until I get my general license. Then plan on getting a true mobile (most likely a kenwood or icom). Calgary is about 80km from the Cdn Rockies. I spend a good amount of time in Banff and Canmore which is right in the Rockies. I also do some off-roading in the Waiporous area which again is at the base of the Rockies. There are some mountain repeaters that I would like to be able to hit, if I get into trouble in Waiporous (when I get a mobile). And then Cochrane, where I live is in mostly flat land.
So I understand a 1/4" is the best for mountainous terrain (correct me if I'm wrong) and 5/8" would be a good middle of the road for mountain and flat.
The next problem is that I will be mounting it on a Jeep Wrangler JKU and will be mounting it on the front cowl which seems the best for a ground plane.
I hear Larsen is a good model. I don't necessarily want a mag mount. Have a mount for the cowl and can drill it out if necessary. Would also like to fit in garage. I have a 3' firestik which mounts on the front cowl mount and fits in garage so around 36" for total length of antenna.
Can't think of anything else I need to identify. Using a friends Baofeng HT to just monitor as I study and I will have to pick up adapter for where the antenna connects to the antenna.
Based on the above any suggestions on a brand and model number.
Thanks for any feedback
Cheers
Al
Cheers
Al
